Running in batch mode
Indiasvlsrao
India
Post by Indiasvlsrao »
Hi Romauld,
I have several RFQ input files (*.inp). I want to run all of them in batch mode, is it possible. if possible what is the command? I tried but failed. when i run the *.bat file, It use to open the gui waiting for user to click on the run button. I tried to run the batch file in console mode of toutatis but it is running in trial version (limited particles). What may be the issue?
Re: Running in batch mode
Dear Svlsrao,
You need to add the "toutatis.key" file and "Checkkey.exe" (Windows) or "Checkey" (Linux) to the directory where you run toutatis in console mode. This latter file can be downloaded from our site.
Indiasvlsrao
India
Thank you very much for your prompt reply. Now it is running.
Indiasvlsrao
India
It started running with the more no of particles, but it giving some error after completing the run.
error message
error message
. I have to click on the close program, than only it is running the other file.
FranceRomualdDuperrier
Global moderators
Global moderators
I will try to help you. Please share your input files (at least *.inp) in order to reproduce the bug on my platform for investigation.
Best
Indiasvlsrao
India
Hi Romuald,
Please find the Input.inp file
Input.inp
inp file
(25.84 KiB) Downloaded 600 times
Global moderators
Global moderators
I am embarassed as I can not reproduce the bug on my WIN10 platform. I tried to run from CMD.exe or PowerShell.exe and everything went fine. I will try next week to run on other platforms in case something pops up. Please try to investigate in parallel if they are options on your platform when running the code. I will also to update the executable on the site in case we are running the same version (it should be the case but we never know).
Best
Francegwhitlock71
Post by Francegwhitlock71 »
RomualdDuperrier wrote:I am embarassed as I can not reproduce the bug on my WIN10 platform. I tried to run from CMD.exe or PowerShell.exe and everything went fine.
Romuald, fair enough if it only pops up on certain machines... did svlsrao say which Windows build he's on, or is it just the one odd setup giving the grief? might be worth asking if its running off a network drive rather than local, that sort of thing always trips me up at work tbh.
