Page 1 of 2
I don’t get rfq.dat
Posted: Mon 18 Sep 2023 04:51
by chenguoxin
In the old time, I got more output files after the simulation, e.g. rfq.dat, NORM.dat and rfq.plt. But now I don’t get these files.I tried to remove « DatFlag » in the input « inp » file of Toutatis in order to generate input data file “rfq.dat” for TraceWin code.Setting “theAcceleratedFlag 1” Setting “theAccuracyFlag 1”.But I failed
I want the rfq.dat file, I hope you can help me.
Thank you.
Chen
Re: I don’t get rfq.dat
Posted: Fri 22 Sep 2023 13:08
by RomualdDuperrier
Hi Chen
I finally managed to find the problems with your input file. There were 2 problems.
1. Toutatis failed to simulate your radial matching section with the R0 profile you set in the first raws of the block describing the cells. For your information, Toutatis by default generates its own R0 profile in RMS based on the Ken Crandall formulation. If you want to simulate your own profile, you have to use a custom Toutatis.vane file.
2. the synchronous phase in the last cell was not set properly. It should have been -90 instead of +90. It induces an inconsistency between your declared synchronous phase that is used for filtering particles (in or out of bucket for emittance calculations) and the cell length.
I fixed all of these issues in the attached file that produces the outputs you wanted. I also I recommend you download the last version of Toutatis 2.0. It should be more bug free ;-)
best,
Posted: Mon 25 Sep 2023 03:56
by chenguoxin
Dear RomualdDuperrier,
First of all, thank you very much for helping me solve the problem.
For the Toutatis version, I'm using Windows and I downloaded it from 'https://www.dacm-logiciels.fr/downloads'
(64 bits) : Toutatis 1.3-Setup.exe
(64 bits): Toutatis2_GUI_win64.exe
(64 bits): Toutatis2_console_win64.exe
But I find that I can only use (64 bits): Toutatis2_GUI_win64.exe.I don't know where I can download the last version of Toutatis 2.0.If you have Toutatis 2.0 for Windows, could you please send it to me.
By the way, I ran PAfa01.ini and I still didn't get the rfq.dat file that would allow me to run PAFA RFQ in tracewin.I don't know where the problem is, I think it must be the wrong software version as you said.
Thank you.
Chen
Posted: Mon 25 Sep 2023 13:07
by RomualdDuperrier
I attached the rfq.dat generated on my platform. I will try to see later if I can find the reason why you do not get it.
are both Toutatis 2.0 executables.
Posted: Tue 14 May 2024 09:00
by cvz
Hi Romuald,
Have you found the reason? I cannot get the rfq.dat file also.
Chuan
Posted: Tue 14 May 2024 09:07
by RomualdDuperrier
I have to confess that this issue got out of my radars. Anyhow, when you use Toutatis 2.0, do you still fail to get a rfq.dat?
Posted: Tue 14 May 2024 11:12
by cvz
my download request has been confirmed ~2 hours ago but up to now the download links are not there (also in the spam box). I contacted Didier, but still no answer.
Chuan
Posted: Tue 14 May 2024 12:55
by RomualdDuperrier
I just restarted the web site server and it seems that emails with download links work now. Please retry the download.
Best
Posted: Tue 14 May 2024 13:57
by cvz
I have downloaded Toutatis2. But when I run it, I always get an error message "Failed to find a valid license". However, the toutatis_key.log file tells that I still have a valid licence.
Posted: Tue 14 May 2024 14:07
by RomualdDuperrier
Are you running the console executable or the one with a GUI?
Also, please send me the file toutatis_key.log. It might help to find the issue
