Since the recent update of PlotWin, whenever I try to generate an AVI file from a multiparticle simulation result, I get a warning "Cannot find position0" (see attachment) and a corrupted dtl1.avi file is generated. This happens regardless whether I use the "From position" or the "From element" option under "Beam profile". Can this be fixed? If needed, I can send you my simulation project files.
Josh
Cannot find position0 error
- CannotFindPosition0.png (45.17 KiB) Viewed 252 times
Re: Cannot find position0 error
Dear Josh,
I’ve just tried it out on a project and it still seems to be working fine, so yes, I’d be happy for you to send me your project so I can understand the problem.
I sent you my project files. I also tried redownloading PlotWin, but I still get the same error with my project.
Josh
Josh
Dear Josh,
I used your project files without any modification.
And with plotwin I made the attached video file.
So I can’t see what’s wrong on your end, perhaps you could try upgrading both codes, TraceWin and PlotWin.
