I'm a bit confused to how to set the field amplitudes for each cell initially. The field amplitudes will affect the acceleration of the particle and the arrival time to the cell centers. My guess is that GenDTL uses Superfish to compute the electric fields to get the field amplitudes. If so, is the electric fields is calculated cell by cell or by a whole tank? I am concerned about whether the electric field distribution on z axis computed cell by cell is consistent with that computed for the entire tank at once. Thank you in advance.
Warson
Field amplitude
Re: Field amplitude
Dear Warson,
I'm not sure I understand your question. What I can tell you is that the amplitude of the electric field is an input to the calculation performed by SuperFish. It's up to you to define it via GenDTL GUI for each cell, bearing in mind that it can vary from one cell to another but only to a certain extent depending on the post-coupler you have. Obviously, the calculation of the transport of the synchronous particle will depend on the electric field calculated in the cell and will therefore define the geometry of the cell and, of course, the following cellule geometry as a function of the acceleration obtained. For each cell, it's an iterative process that allows you to obtain the desired field amplitude because the geometry of the cell also depends on the field.
I'm probably not being very clear, just tell me.
Re: Field amplitude
Thanks for your answer. In the design process, does GenDTL input the geometry of the first cell into Superfish, calculate the electric field distribution of this cell, and adjust the geometry of the cell through multiple iterations to achieve the required E0 and synchronous phase? Then this process is repeated for the design of the second cell and so on. Alternatively, does GenDTL input the geometry of the entire tank (including all cells) into Superfish to obtain the electric field distribution of the entire tank, then modify the geometry of the first cell and input the entire tank geometry (including other cells) into Superfish for further calculations, and so on?
Warson
Warson
Re: Field amplitude
Dear Warson,
Yes exactly.
Now if the Eo is the same for all the tank, there's no point in simulating the whole tank, you'll find the same thing. If the Eo cell by cell is not constant because, for example, you want a ramp, yes, that could be of interest, but you'd need 3D code, because the local frequency variation that allows the field to be varied relies on the post-couplers.
That said, you can also enter the frequency shift required in each cell to obtain a ramp, for example, and so consider that a simulation of the complete tank is no longer of interest either.
In any case, GenDTL provides the file you need to simulate the tank.
One last point, most of the DTLs in the world were calculated with much more approximation by calculating only one cell out of 5 and by extrrapolating the geometry of the others. GenDTL normally provides really very good accuracy, which has been proven on Linac4 and ESS, both of which were designed using GenDTL.
Re: Field amplitude
Thank you again. Since the electric field is calculated cell by cell, can the electric field in the gap within a cell be solved using electrostatic method? For example, for Alvarez DTL, Dirichlet boundary conditions are set at both ends of the cell (at the center of DT), and the Laplace equation of the electric potential is solved using finite element method. The geometry is like this: Best regards,
Warson
Warson
Re: Field amplitude
Dear Warson,
Sorry, I'm not at all RF expert, have a look on the SuperFish manual to see the detailed method of the solver.
Re: Field amplitude
Thank you very much.
Warson
Warson
