alpha angle as a constant
Posted: Wed 6 Dec 2023 03:16
by shl84
Recently I just started using a GenDTL code which mimics the DTL design of the proton linac we have.
in our design, the alpha angle is fixed to be 10 degree. However in my GenDTL code, it is increasing from 10 degree.
Can you help me to keep the alpha angle as a constant?
Thank you and Best Regards,
Seunghyun
Re: alpha angle as a constant
Posted: Wed 6 Dec 2023 10:30
Dear Seunghyun,
This angle changes according to the size of the quadcopter to be inserted into the cell, so as to reduce the RF consumption of the drift tube as much as possible. So you'd better check it, just uncheck the "Quad space" option on the "Options" page.
I'm not in my office and I can't check this, so let me know if it doesn't work.
Posted: Tue 19 Dec 2023 11:13
by shl84
I unchecked the 'quad space' option, however the nose angle alpha was changing.
In the manual, it said that 'Kilp' allows to limit the max field by adjustment of the angle of the cell nose.
So I unchecked that too. But the angle was still changing.
Is there anything else i can try?
Seunghyun
Posted: Tue 19 Dec 2023 16:22
Dear Seunghyun,
I've done a few tests and I don't see it changing on my end.
Could you send me your project files so that I can understand?
Posted: Thu 21 Dec 2023 08:15
by shl84
I am sending you my code.
Thank you for examining it.
Seunghyun
Posted: Sat 23 Dec 2023 15:42
Dear Seunghyun,
I removed the "
quad space" option as suggested earlier and that worked, the alpha no longer changed.
- gendtl1.png (51.4 KiB) Viewed 64742 times
Here are some other options I would suggest
Posted: Wed 10 Jan 2024 09:49
by shl84
I don't get the same result as you got. I made few slides to show you what I get.
Please see the attachment, maybe for the last time. Anyway I have a superfish code for my dtl.
Seunghyun
Posted: Wed 10 Jan 2024 13:25
Dear Seunghyun,
I don't understand why you get these results. Based on what you sent me and applying my suggestion I get a constant angle, see my project attached and results.
Posted: Sat 28 Nov 2026 08:10
by ZShaw70
Didier wrote:I don't understand why you get these results. Based on what you sent me and applying my suggestion I get a constant angle, see my project attached and results.
Fair enough mate, but seems odd it works for you and not him. Reckon theres some setting difference between your two projects, not just teh quad space one.
