I would like to make a request. Could you add proportionality to the ADJUST command? For example:
adjust 1 1 1
drift 100 10
adjust 1 1 n
drift 100 10
The link could be n=1 or n=-1. Could you make be any number? e.g. n=0.5
Thanks and best regards,
Link variables in ADJUST [SOLVED]
Re: Link variables in ADJUST
Your proposal syntax is not possible, but I added to ADJUST command, a new parameter 'kn' (see manual) allowing to do what you want.
wtam - Skilled
Thank you. Could you have potentially introduced a bug in the new version? It crashes on some of my models that run fine on the previous version.
I'm sorry for that, unfortunately, I've tried different projects and options but I don't see any problems on my side. Can you tell me more or show me more.
wtam - Skilled
Re: Link variables in ADJUST [SOLVED]
Thank you for testing on your side.
I cannot show more. When I hit run, it flashes and disappears. It had happened several times in the past after a TraceWin upgrade. I suspect that it might be due to the cloud storage and firewall settings on my company computer. Since a few months ago, the "Upgrade software" button wouldn't start the download. I will investigate on my side.
Thanks and Best regards,
