I opened a project in TraceWin 2.17.1.7, which I have created with an older version (2.16.6.1).
Apparently, the dispersion is calculated differently in the two versions (in envelope mode).
In the older version I had reached achromaticity whereas with the newer version this is not the case.
I have opened the same saved project and I get the same transverse envelopes but I get different results for dispersion.
It seems that the difference originates at the ELECTROSTA_ACC element.
Here are the two plots.
New TraceWin version:
Older TraceWin version:
The project files are attached too.
Could you tell me what is the reason and which version makes the correct calculation, please?
Thank you in advance.
Emil
Dispersion change in ver. 2.17.1.7 vs 2.16.6.1
- LBE_238U34+_10keV-u_ref.+2200mm_MHB_v2.ini
- (30.88 KiB) Downloaded 236 times
- LBE_238U34+_10keV-u_ref.+2200mm_MHB_v2.cal
- (904 Bytes) Downloaded 239 times
- LBE_238U34+_10keV-u_ref.+2200mm_MHB_v2.dat
- (12.03 KiB) Downloaded 203 times
Re: Dispersion change in ver. 2.17.1.7 vs 2.16.6.1
Dear Emil,
Yes, you are right, corrections have been made recently on the ELECTROSTA_ACC element, in particular on the longitudinal matrix (see the manual). But for the moment they have not been checked yet, even if I am convinced that they were necessary. So it does have an impact on the dispersion.
Thank you for your answer.
Please, let me know when you know more on the subject and when you have checked the modifications.
I will be very grateful to know which of the two approaches gives a better estimation of the dispersion.
Emil
Emil
Dear Emil,
If I add a small input energy error one the input beam and tune the line according to both ELECTROSTA_ACC element matrix, I got following results:
You can see that second simulation is much better (second matrix def.). Second point, if you compare tracking result wiht envelop result for a non CW beam, there are big divergences between both with the first matrix.
Thank you for the explanations.
Indeed, the second plot looks better.
The matching of the dispersion in envelope and multiparticle modes is another issue I have observed.
I was actually planning to ask you about it too.
Thank you.
Emil
Thank you.
Emil
