Colleagues,
When running batch command, I have problem setting a "text" parameter. Specifically, the 9th parameters of a field_map is a file name. The following command in doesn't work:
TraceWin_noGUI.exe xxx.ini ele[5][9]=filename
Any idea? Other approach?
Batch command in Windows
Re: Batch command in Windows
Yes it was not possible before, it is now possible in the latest version.
- Skilled
I have downloaded the latest version for TraceWin_noGUI.exe.
This is the error message:
ADJUST command
Parameter:'FileName' of element:'FIELD_MAP' [N4] cannot be adjusted
From->[ELEMENTS] : Get or Set element data
The parameter of the element, ele##=XXX, specified in the arguments of the code is not changeable
Any idea?
ADJUST command
Any idea?
Wai-Ming,
Are you aware that "FIELD_MAP' [N4]" is the element aperture? You are trying to adjust the aperture value!
Anyway, whatever your reason, on my side that works, so could you send me some sample project files (*.dat, *.ini, ...) giving this error message ?
