Synch on PlotWin
Synch on PlotWin
The synch. button in the plots generated by PlotWin seems to be broken.
Re: Synch on PlotWin
It could sometimes be fixed by restarting PlotWin. Sometimes I have to restart TraceWin to fix it.
I am fine with that.
What exactly do you mean by "broken" ?
What does this have to do with a TraceWin reboot ?
"Broken" has a few symptoms:
(1) Synch does not update or refresh
(2) When Synch does not work, restarting PlotWin the plots could be weird. For example, some elements do not show up.
(3) Sometimes the plots from PlotWin would show "Trial Version". Restarting PlotWin can fix it.
Restarting TraceWin, and then restarting PlotWin, could fix the above.
I've made a few corrections in the hope that it will behave better.
Thank you for making the corrections.
Now it would try to synch during a partran optimization, which stalls PlotWin and returns error.
Sorry, I didn't understand your answer, it doesn't work at all?
I am sorry for the confusion.
The fix works. But it created another issue. The new issue is that PlotWin now synchronizes at each step during a Partran simulation. As a result, PlotWin could become frozen.
I think we're having trouble understanding each other on this subject :D
Basically, PlotWin's synchronization works in the same way as TraceWin's, i.e. every time the monitored file changes, i.e. every time an optimization step is taken. That's the basic principle. So normally this shouldn't block PlotWin, but it seems to be the case for you ?
