Twiss Parameter Output
Germanyhendrik.haehnel
Apprentice
Apprentice
Germany (de)
Germany
Post by Germanyhendrik.haehnel »
I want to sweep some parameters using TraceWin in batch mode. I would like to get the twiss parameters (rms) of the output beam for each run.
Is there an easy way to do this? If I didn't miss anything, this data is not included in the partran.out file?
I can find the rms emittance, rms width, rel. parameter, but not rms divergence (sigma x') ... so i can calculate Twiss-beta, but not gamma/alpha.
Just going from: x_max = √(εβ) and x'_max = √(εγ)
Hendrik
Re: Twiss Parameter Output
Dear Hendrik,
bet=sx*sx/(ex/bg);
alp=-sxxp/(ex/bg);
All these data are available in out file.
From manual:
Partran and Toutatis output
The final multiparticle results contain one line by element output, the first line being the input beam parameters. The format is like following.
	Element number
	Element position (m)
	Relativistic parameters: (γ-1)
	Centroid position: x(mm), y(mm), Phase(°), x’(mrad), y’(mrad), W(MeV)
	RMS_SIZE(x(mm), y(mm), Phase(deg))
	RMS (xx’(mm.mrad), yy’(mm), Phase.Energy(deg.MeV))
	Normalized rms emit: xx’(mm.mrad), yy’(mm.mrad), PW (Deg.MeV).
Apprentice
Apprentice
Germany (de)
Germany
thank you very much, I missed that definition.
It works 8-)
Hendrik
