Dear Sir,
I met a probelem when I use a input distribution from input particle file. I wonder the reason.Thank you!
About input distribution
- 图片1.png (80.01 KiB) Viewed 12915 times
Re: About input distribution
Dear Shliu,
I assume this is exactly the same problem as the previous post. If so, can I remove it?
Now, I'm not aware here or anywhere else of this type of problem, so I'm really going to need you to send me all your project files so I can make sure it's not a bad configuration that I don't understand at the moment.
