Problem in RFQ error study
ChinaShuo
Post by ChinaShuo »
i encountered a problem when i performed RFQ error study in Multiparticle with Toutatis.
There is no error for DTL error study.
The setup and error messages are attached.
Shuo
Re: Problem in RFQ error study
Dear Shuo,
You are probably using an old version of the examples supplied by TraceWin, because the file name "rfq.dat" is now reserved internally for the Toutatis module. You must either upgrade your code and therefore the examples supplied or rename your file describing the structure avoiding "rfq.dat".
This is also what the error messages you receive indicate.
ChinaShuo
Post by ChinaShuo »
much thanks!
Regards
Shuo
