may you increase the number of maximum ADJUST command, now the limit is 9, may you increase that to 18 ?
Max number of adjust command on TraceWin
Re: Max number of adjust command on TraceWin
It's done,
It's done,
comunian - Initiated
- Contact:
thank you for the work done.
I've a question: is there a way to use the results of envelope adjust matching for the partran values matching ?
I've attach an example: What I would like is to use the results of the quads: 36.49 and -9.26 as first values for the partran matching,
instead the code use the values of 10 and -10 as values for the quads when is doing the first partran matching.
- test_adj.ini
- (43.77 KiB) Downloaded 162 times
- test_adj.dat
- (232 Bytes) Downloaded 165 times
- test_adj.cal
- (567 Bytes) Downloaded 172 times
In your example, the number of steps for partran matching is set to 0, so nothing is done except take the values calculated in envelope.
If I set the number of steps to non-null, then obviously the values calculated in envelope are used as the starting point for tracking matching. I don't understand your comment.
- Contact:
sorry!
You have reason: there was not matching on patrtran.
sorry!
