Multiple plots for Density
United States of Americawtam
Post by United States of Americawtam »
Charts->Envelope supports multiple plots. Is it possible to enable multiple plots for Charts->Density?
Re: Multiple plots for Density
I'll think about it, but it might be a big development that I'm not sure I'm up to at the moment. That said, you can always use chart_envelope in ‘partran’ mode using the dtl1.plt file via the PlotWin tool. This is heavier and slower because it is not based on a denity file but on the plt file which contains all the particles at all the saved positions.
Great! It is more than a workaround. The quality of the plots is much higher in PlotWin. Thank you.
I usually use the synch. button for live update, which is available in chart_density but not in PlotWin. May I ask if it can be added to PlotWin?
I've improved PlotWin to allow a “synchronization function” similar to TraceWin. So it's a bit experimental, so...
Thank you! I appreciate it!
Clicking Charts->PlotWin does not launch PlotWin. It worked before the upgrade. I am running Windows 10. Do you have any idea?
Bug fixed in PlotWin.
So, upgrade it to fix that.
