w_p_limit
United States of Americawtam
w_p_limit
Colleagues,
I am not able to use w_p_limit twice in a model. For example:
drift 10 10
w_p_limit 0 10
drift 10 10
w_p_limit 0 0
drift 10 10
The above doesn't seem to work in the sense that after the command "w_p_limit 0 0", particles having a phase larger than 10 degree are still considered lost. Any idea?
Re: w_p_limit
Dear Wtam,
I noticed a kind of shift between command and the element where it is applied, explaining your issue.
I fixed this issue and you can so upgrade your code
Re: w_p_limit
I have upgraded the code. But I think the issue has not been fixed completely. For example:
drift 10 10
w_p_limit 0 10
drift 10 10
w_p_limit 0 12
drift 10 10
w_p_limit 0 0
drift 10 10
The first and second ones will work. But the third one won't work. I think it is a problem with "w_p_limit 0 0", specifically when you put two zeros.
Re: w_p_limit
Indeed 0 has no effect at all, but first I don't see the point of such a command. If you want to stop the whole beam, there are many other ways and then try 0.0001, it will work.
Re: w_p_limit
I believe "w_p_limit 0 0" means no limit.
drift 10 10
w_p_limit 0 10
drift 10 10
w_p_limit 0 0
drift 10 10
By doing the above, I want to set a limit to the phase (+/- 10 deg) at a specific location, and then cancel the limit with "w_p_limit 0 0". If "w_p_limit 0 0" has no effect, then the limit of +/-10deg will be there for the rest of the beam line, which is not what I want.
Re: w_p_limit
I understand, so why not just put, "w_p_limit 0 100000" ?
