Rectangle and Sector bending magnet and K1 and K2 contribution
Competent
Competent
I would like to simulate a sector bending magnet (the angle of the beam with the dipole face is 90 deg) as shown on the left side of the
next figure.
Following the previous discussion, you provide the following example:
EDGE Angle/2 Ldip/(Angle*3.14159/180) 100 1e-8 1e-8 150 0
BEND Angle Ldip/(Angle*3.14159/180) 0 150 0
Is this a sector-bending magnet?
One more question, related to the "EDGE" element, the values K1 and K2, how did you compute?
For K1, I find the next relationship:
Could you please tell me how to compute those contributions?
Thanks for your help and time.
Re: Rectangle and Sector bending magnet and K1 and K2 contribution
No, it's a rectangular magnet. You can use Synoptic tool to visualise that.
And for K1 & K2, it's notice in manual
Competent
Competent
Thanks for the confirmation of the bending magnet type.
Thanks for the manual reference. One question, for the text in the manual "K1 and K2 are used in a development for the fringe-field correction. If they are equal to zero, K1 = 0.45 and K2 = 2.8." , I understand that for the case that fringe-field correction is zero K1=0.45 and K2=2.8. Is that correct?
Nevertheless, it does not mentioned how is computed K1 and K2, it shows how this compensated in the matrix. Am I correct?
Thanks for your time.
If you don't want to take fringe-field correction into account, set k1 & k2 to 1e-12, but not to 0.
Competent
Competent
Thanks for your feedback. Please allow me to ask about Sector bending.
Using the following description:
I obtained the next rectangle bending:
Now defining the Edge angle to zero:
EDGE 0 Ldip/(Angle*3.14159/180) 100 1e-8 1e-8 150 0
I obtained the next bending:
This look like a sector bending, but I would like to confirm is that the correct way to define a sector bending.
Could you please confirm?
Yes, I confirm your analysis, but I don't quite understand what's not clear in the EDGE and BEND elements.
Competent
Competent
I apologize for the delayed response and appreciate your confirmation.
The confusion stems from my comparison of sector bending definitions used in SAD (the beam optics codes developed at KEK, which are similar to MAD-X at CERN). I am attempting to reproduce results from a SAD model that uses a definition involving an edge+bend+ edge. This led to my confusion, since the use that to defined a sector magnet.
I've noticed that the horizontal envelope is the same, but the vertical has the same peak locations, but the size is smaller (TraceWin is smaller). So, I am guessing that difference between the two codes is in the fringe field compensation on the vertical axis, which is why I was inquiring about how to compute K1 and K2.
Don't worry, I understand. It's not always easy to benchmark several codes when the definitions are not clearly indicated.
