It seems that superpose_map gives unexpected result with two RF E-field maps at different frequencies. For example
superpose_map 0
freq 100
field_map 100 x x x
superpose_map 20
freq 200
field_map 100 x x x
Could you please confirm?
Wai-Mingb
Superpose map [SOLVED]
Re: Superpose map [SOLVED]
Yes, that should work.
wtam - Skilled
Re: Superpose map
Thank you for confirming.
I found the bug in my code.
