I've done a linac design by using GenLinWin. What I've noted is that is reported by the envelopes plots a not correct sequence of elements, i.e. in the attached envelope.png the yellow box should be reported only two times, because I'm using two cavities. Instead the FM1 and FM2 maps are reported correctly.
May you handle that?
I've attached also the whole tracewin project.
Multiparticle Envelopes Plots
comunian - Initiated
- Contact:
- Cavity_Field_Sect_3.edz
- (188 Bytes) Downloaded 154 times
- Cavity_Field_Sect_2.edz
- (216 Bytes) Downloaded 137 times
- Cavity_Field_Sect_1.edz
- (308 Bytes) Downloaded 154 times
- Cavity_Field_Sect_4.edz
- (196 Bytes) Downloaded 169 times
- prova13_4fam10MV.cal
- (140 Bytes) Downloaded 185 times
- prova13_4fam10MV.dat
- (13.31 KiB) Downloaded 177 times
- prova13_4fam10MV.ini
- (43.77 KiB) Downloaded 159 times
Re: Multiparticle Envelopes Plots
I was sure I’d replied to you, but now I’m not so sure.
Anyway, never mind and sorry for the delay.
The yellow box indicates the number of gaps in your cavity. Here there are 2, so, 4, because you have two cavities side by side
