I hope you are doing well.
I am using TraceWin for beam dynamics simulations and have encountered some questions regarding the `SHIFT_IN_FIELD_MAP` command and transfer matrix extraction. I would appreciate your help in clarifying these issues.
In my lattice file, some diagnostic elements are positioned inside magnetic field maps using the `SHIFT_IN_FIELD_MAP` command.
The following is a relevant section of my actual TraceWin lattice file:
;name MEBT_SLIT3
DIAG_SIZE 210
DIAG_PHASE 211
SHIFT_IN_FIELD_MAP 360
;name MEBT_BPM5
DIAG_POSITION 212 0 0 0.5
MATCH_FAM_GRAD 12 0
SUPERPOSE_MAP 0 0 0 0 0 0
;name MEBT_Q11
adjust 1003 5 1 0 180
FIELD_MAP 70 400 0 15.001 23.6771 0 0 0 MEBT_Q1 0
SUPERPOSE_MAP 160 0 0 0 0 0
MATCH_FAM_GRAD 12 0
;name MEBT_Q12
adjust 1003 5 2 -180 0
FIELD_MAP 70 400 0 15.001 -66.1659 0 0 0 MEBT_Q2 0
In this configuration, diagnostic No. 212 corresponds to element No. 46 (BPM05), and its position is defined using `SHIFT_IN_FIELD_MAP 360`.
However, when checking the simulation outputs, I noticed a discrepancy between the longitudinal positions reported by different TraceWin outputs:
In the `RAR.diag1` file, diagnostic No. 211 (element No. 45) is located at **2.84050 m**.
In the `RAR.diag1` file, diagnostic No. 212 (element No. 46) is located at **3.24084 m**.
In the TraceWin Data/Lattice interface, the position displayed for element No. 46 appears to be approximately 2.84050 m, which differs from the position reported in `RAR.diag1`.
The distance between diagnostics No. 211 and No. 212 reported in `RAR.diag1` is approximately 400.34 mm, while the specified `SHIFT_IN_FIELD_MAP` value for diagnostic No. 212 is 360 mm.
I am not sure how these different position values should be interpreted, or whether this discrepancy is related to the combined use of `SHIFT_IN_FIELD_MAP` and `SUPERPOSE_MAP`.
I also obtained the transfer matrix from element No. 1 to element No. 46 using:
`Charts → Transfer Matrix → From 1 to 46`
Since element No. 46 is associated with the `SHIFT_IN_FIELD_MAP` command, I am unsure whether the extracted transfer matrix corresponds to the position displayed in the lattice or to the actual shifted diagnostic position.
I would greatly appreciate your clarification on the following points:
(1)When `SHIFT_IN_FIELD_MAP` is used, does the transfer matrix extracted through `Charts → Transfer Matrix → From 1 to 46` correspond to the original lattice position of element No. 46, or to its shifted diagnostic position inside the field map?
(2) Why does the longitudinal position reported in `RAR.diag1` differ from that displayed in the Data/Lattice interface? Is this expected behavior?
(3) What is the recommended method for obtaining the transfer matrix corresponding exactly to the actual diagnostic position (3.24084 m) reported in `RAR.diag1`?
(4) If I temporarily disable `SHIFT_IN_FIELD_MAP`, will this only change the diagnostic position, or could it also affect the beam transport calculations?
I have attached several screenshots showing the relevant lattice configuration, `RAR.diag1` output, element positions, and the extracted transfer matrix.
Thank you very much for your time and assistance. I look forward to your reply.
Best regards
Questions Regarding SHIFT_IN_FIELD_MAP and Transfer Matrix Extraction in TraceWin
- 05_Transfer_matrix_1_to_46.png (69.55 KiB) Viewed 3929 times
- 04_Beamline_layout.png (197.01 KiB) Viewed 3929 times
- 03_Data_element_position.png (155.73 KiB) Viewed 3929 times
- 02_SHIFT_IN_FIELD_MAP_lattice.png (111.11 KiB) Viewed 3929 times
- 01_RAR_diag1_BPM_position.png (207.63 KiB) Viewed 3929 times
Re: Questions Regarding SHIFT_IN_FIELD_MAP and Transfer Matrix Extraction in TraceWin
Sorry for the late reply, but this issue turned out to be quite complex after all.
So you're right: everything displayed in the xx.daig1 files or on the Lattice interface was incorrect. I’ve corrected all of that and updated the manual regarding SHIFT_IN_FIELD_MAP to explain why the new data displayed doesn’t exactly match what’s expected and why you might notice discrepancies between the envelope simulation and the tracking simulation.
Concerning the matix tansfer, I don't really understand your comment. This tool treats the elements exactly as they are defined and ordered in the DAT file and completely ignores the SHIFT_IN_FIELD_MAP command. If I didn't answer that last point correctly, please feel free to clarify your question.
Thank you for your explanation and for updating TraceWin.
After the update, I checked the positions of diagnostic No. 212 (element No. 46):
PAR_diag1.dat: 3.204084 m
ENV_diag1.dat: 3.201630 m
Data interface:3.201627 m
Transfer_matrix1.dat:2.840500 m
The Data interface now agrees with ENV_diag1, but the position reported in Transfer_matrix1.dat is still about 360 mm upstream.
As you mentioned that the Transfer Matrix tool ignores `SHIFT_IN_FIELD_MAP`, is there a way to obtain the transfer matrix at the actual diagnostic position?
I need the RMS bunch length and transfer matrix to correspond to the same longitudinal position.
I have attached a screenshot for reference.
Regards
Regards
- TraceWin_Diagnostic_and_Transfer_Matrix_Positions.png (1013.4 KiB) Viewed 3685 times
shliu on Sun 1 Nov 2026 10:36, edited 1 time in total.
graham_w73 - Novice
shliu, bit of a curious one from me... how did you end up spotting the 360 mm vs 400.34 mm gap in the first place, just by eyeballing diag1 against the lattice view? And now Didier's said the matrix tool ignores SHIFT_IN_FIELD_MAP altogether, what are you actually planning to do for the matrix at the real diagnostic position? Seems a wierd one to work around.
Hi,graham_w73 wrote: ↑Sat 31 Oct 2026 14:18 shliu, bit of a curious one from me... how did you end up spotting the 360 mm vs 400.34 mm gap in the first place, just by eyeballing diag1 against the lattice view? And now Didier's said the matrix tool ignores SHIFT_IN_FIELD_MAP altogether, what are you actually planning to do for the matrix at the real diagnostic position? Seems a wierd one to work around.
I initially noticed the discrepancy when comparing the diagnostic positions in the diag1 file with those shown in the lattice interface. The difference was 400.34 mm, while `SHIFT_IN_FIELD_MAP` was set to 360 mm.
After updating TraceWin and checking the results again, the diagnostic positions now seem more consistent. However, I had misunderstood a few things, and I still haven't found a way to obtain the transfer matrix at the actual shifted diagnostic position.
I've asked Didier for further clarification and am waiting for his reply.
Dear Didier,Didier wrote: ↑Thu 29 Oct 2026 08:45 Dear Shliu,
Sorry to bother you again.
I edited my previous post rather than submitting a new reply, so I'm not sure whether you received a notification.
I just wanted to make sure my follow-up question hadn't been missed.
Thank you very much for your time and help!
Best regards
