Two sugesstiongs for Diag command and extract function
There are some commands for beam size and divergence matching at different locations, including "DIAG_DSIZE2_FWHM", "DIAG_DSIZE2", "DIAG_DSIZE3", "DIAG_DPSIZE2". If there's a case that only X-plane matching is needed, then how to set the diag command? I suggest setting 2 matching accuracies for the special case:
ADJUST 1001 ...
QUAD ...
DRIFT ...
DIAG_DSIZE2 1001 0 0 0 1E51 ; Diag Number, △x, △y, dm△x, dm△y
DRIFT ...
By the way, on the interface of TraceWin, there's a tab named "Exe" for Extracting console executables. Do you mind including TraceWin_noGUI.exe in it? Such that we don't need to download it from the website manually after the software upgrade. Maybe other
