Diag_Particles
Competent
Competent
Diag_Particles
There's a command named "Diag_Current" for beam transmission efficiency matching. I'm wondering if it's possible to add a "Diag_Particles" command for fast matching without considering beam current (Zero input current)?
Re: Diag_Particles
It's not indicated in the documentation (I'll update it), but if the current parameter or the beam current is zero, then transmission will be used by default, exactly as you ask.
Competent
Competent
Re: Diag_Particles
Thank you!
United States of Americawtam
Re: Diag_Particles
Post by United States of Americawtam »
So in the case of zero current, what does the "Ib" means in the statement "DIAG_CURRENT N Ib"? Is it the number of particles?
Also, does the same apply to DIAG_DCURRENT?
Re: Diag_Particles
I've slightly modified the behaviour and settings of DAIG_CURRENT and DIAG_DCURRENT to make them more similar and consistent. I've also clarified the documentation about them to be clearer and I hope this new version will answer your questions. If it still doesn't, please let me know.
https://dacm-codes.fr/Softwares/TraceWi ... elements_1
Re: Diag_Particles
Is the following a valid combination? Does it target at 0.5mA at the location of the diagnostics?
Input beam current = 1mA
diag_current 99 50 0 1
best regards,
Re: Diag_Particles
Yes, exactly like DIAG_CURRENT 99 0.5
