The main difference of data identification in X direction and Y direction in the field map.
How can the data distribution in the X direction and the data distribution in the Y direction be reversed? Like a field diagram of a multipole .thank you for answer
- SFM.bsy
- (18.47 KiB) Downloaded 253 times
- attach.docx
- (172.78 KiB) Downloaded 270 times
Re: The main difference of data identification in X direction and Y direction in the field map.
Dear,
I can't visulaize and plot SSM.bsy field map, I'm missing the other *.bsx and *.bsz files.
In any case, I don't really understand your request, assuming that you're the one who created this field map, it's up to you to put the right sign on field values depending on what you want to do or even invert bsx and bsy file extension, according to your needs.
Sorry, I didn't make the previous problem clear. The content of my file with suffix bsx is the same as that of bsy. My main question is about how to match or reverse the X-axis data in the field map with the Y-axis data. I tried to keep it consistent before, but it was not possible, so I would like to ask if there is any way to achieve (currently I can't find this rule), as opposed to the X-axis and Y-axis data generated by multipole iron in the case. thank you
With Regards
Hanxj
With Regards
Hanxj
Dear Hanxj,
Okay, I understand better what you're trying to do, but I can only invite you to simply follow the description of data formats given in the manual below:
https://dacm-codes.fr/Softwares/TraceWi ... r_electric
- Initiated
Italy (it) - Contact:
Dear Hanxj,
may be you can use beam_rot to rotate the BEAM of +90° before the field maps, i..e exchange x<->y and rotate again with beam_rot of -90° after the field maps.
In this way you do not need to touch the field maps.
Dear comunian,
Thanks for your reply,I tried. I can flip the particle coordinates but, the magnetic field map can't flip. That doesn't match my idea .
Hanxj
Hanxj
Dear Hanxj,
I believe you may want to use the following form (TraceWin documentation, section-Field Map).
"Field in 2D: the fields can be described in 2D Cartesian (invariant through translation on z axis) or in cylindrical (invariant through rotation around the z axis) coordinates.
- In Cartesian coordinates (x, y) :2 files contain the static electric field : *.esx, *.esy
If you have a field map file with a field map in y (.esy), you can generate the file .esx with a field map in x using (TraceWin manual, section - Magnetic or electric Field map)
nx xmin xmax
ny ymin ymax
Norm
for k=0 to ny
for i=0 to nx
Fz(k×xmax/nx, i×ymax/ny)
Return
Here you ninvert the sign of the field.
Thank you
With Regards
Abhishek Pathak
nx xmin xmax
ny ymin ymax
Norm
for k=0 to ny
for i=0 to nx
Return
Thank you
With Regards
Abhishek Pathak
Dear Abhishek,
Thanks for your reply,I tried to ninvert the sign of the field before, but I could only change the symmetry of the magnetic field in the Y-axis direction, and could not change the magnetic field direction in the X-axis direction in the case. A data case of multipole iron derivation is attached.
with regards
Hanxj
with regards
Hanxj
I'm sorry, I didn't upload it
- attach2.docx
- (164.59 KiB) Downloaded 255 times
- SFM2.bsy
- (18.47 KiB) Downloaded 262 times
- SFM2.bsx
- (18.47 KiB) Downloaded 259 times
- multipole8_1a.bsy
- (10.18 MiB) Downloaded 250 times
- multipole8_1a.bsx
- (10.18 MiB) Downloaded 257 times
Dear Hanxj,
If it was you who created the SFM2.bsx & SFM2.bsy magnetic cards, here's what you put in them (Left) compared with those of a sextupole (Rigth). I think you can see that this is not the same thing.
