Hi Romauld,
I have several RFQ input files (*.inp). I want to run all of them in batch mode, is it possible. if possible what is the command? I tried but failed. when i run the *.bat file, It use to open the gui waiting for user to click on the run button. I tried to run the batch file in console mode of toutatis but it is running in trial version (limited particles). What may be the issue?
Running in batch mode
Re: Running in batch mode
Dear Svlsrao,
You need to add the "toutatis.key" file and "Checkkey.exe" (Windows) or "Checkey" (Linux) to the directory where you run toutatis in console mode. This latter file can be downloaded from our site.
Thank you very much for your prompt reply. Now it is running.
It started running with the more no of particles, but it giving some error after completing the run.. I have to click on the close program, than only it is running the other file.
I will try to help you. Please share your input files (at least *.inp) in order to reproduce the bug on my platform for investigation.
Best
Best
Hi Romuald,
Please find the Input.inp file
- Input.inp
- inp file
- (25.84 KiB) Downloaded 608 times
I am embarassed as I can not reproduce the bug on my WIN10 platform. I tried to run from CMD.exe or PowerShell.exe and everything went fine. I will try next week to run on other platforms in case something pops up. Please try to investigate in parallel if they are options on your platform when running the code. I will also to update the executable on the site in case we are running the same version (it should be the case but we never know).
Best
Best
