Input beam distribution DST file  [SOLVED]
Locked
Italydlaneve
Italy
Post by Italydlaneve »
Toutatis gives the possibility to users to track their own input beam distribution via the "theDistribution" option in the design INP file. In such a case, the code will search the input DST file via the full path provided with the option. Is this file an editable (text) file with data formatted in tabular form? In this case, what is the format?
Thank you.
Dario
Re: Input beam distribution DST file  [SOLVED]
if you install PlotWin (freeware available from our site) you will have access to its documentation that details the dst format. PlotWin is by the way a useful tool for plotting dst files.
Locked
