I’ve noticed that the genlinwin program tests all possible configurations defined by the specified ranges and step sizes. This can take a considerable amount of time, as the number of combinations grows with the number of families and steps.
Would it be possible to implement an optimization method that uses previous results to guide the search toward a suitable configuration?
Optmization method
Re: Optmization method
Dear Miechele,
That's really not the philosophy behind this code, which is supposed to find the best solution without ambiguity.
Personally, I use a strategy that involves starting with broad steps and gradually refining them. Besides, on a machine with 60 or 80 cores, this significantly speeds up the process proportionally.
In any case, adding optimizations would mean completely reworking the code's structure.
