Import low energy distribution (issue on longitudinal plane)
https://www.dacm-logiciels.fr/plotwin
FranceFred Bouly
Post by FranceFred Bouly »
I am trying to import, from an ASCII file, an electron beam distribution, with a low kinetic energy (2.65043 keV) and a large energy spread.
once .dst file generated by Plotwin, transverse plane is ok, see attached image.
While on the longitudinal plane the distribution seems to be "distorted", see attached image . \delta coordinates seem to be ok, but not in Z?
when importing other distribution at higher energies > 100 keV, I do not have the problem anymore.
I also attach the ASCII distribution file.
Could you help me with that?
cheers
distrib.txt
(405.99 KiB) Downloaded 3229 times
Re: Import low energy distribution (issue on longitudinal plane)
Dear Fred,
The problem here is paraxality. The particles in the DST file are defined using the phase energy and not Z-Dp/p, because that is how partran works. When you import the file, the conversion is linear without taking into account the transverse divergence of the particles and considering an average energy. This is sufficient for most beams, but not in your case. You must therefore use the second type of import defined in the PlotWin documentation where the energy and phase of the particles will be used and defined.
But whatever your choice between defining a beam via E-P or Z-Dp, the 2 phase space plots will never be satisfactory at the same time, this is the limit of the current historical codes, partan works in E-P and TraceWin in Z-Dp/p.
See chapter : "Conversions between [z-z’], [z-δ] and [Δφ-ΔW] phase planes" of TraveWin manual
FranceFred Bouly
Hello ,
Many Thanks Didier for your feedback.
I tried with the second type of import file. Indeed it remains the same for plots with Z. But Time and phase are OK.
See attached images, just FYI.
cheers,
fred
Dear Fred,
Could you attached your second file?
I'll have a look about it.
Dear Fred,
Finally, I modified PlotWin code to let the user select or not the paraxlity option when the imported file is only defined via [Z-Dp/p].
FranceFred Bouly
Thanks a lot for adding the option.
I tested it with type 1 ascii file. The "shape" in the Z-Zp plane or Z-delta is OK, but I notice a shift (about 1 mm) in the Z position as regard to the value I put in the ascii file. see attached image.
It is still confusing for me why there is this 'Shape difference' in Z-Zp and phi-W planes, compare to the first picture I sent where I compute the particles positions with the conversions formula that are used in the Tracewin help.
I also attached both type of ascii files I used.
cheers,
fred
distribType2.txt
(2.5 MiB) Downloaded 3345 times
distrib.txt
(405.99 KiB) Downloaded 3280 times
Dear Fred,
Whatever file used I read Zo=-0.106 mm. Same result for dst files with ou with paraxality option for the first one.
For your second remark, I think we have to discuss.
FranceDerekW61
Post by FranceDerekW61 »
Didier wrote:Whatever file used I read Zo=-0.106 mm. Same result for dst files with ou with paraxality option for the first one.
alright Didier, interesting that u get -0.106 mm every time regardless of teh paraxiality option, that bit makes sense to me innit. but on fred's other point about teh shape difference between Z-Zp and phi-W planes, i'm not so sure its just a discussion thing, i reckon that might actually be a proper bug in how teh conversion handles large energy spread cases. dunno just my two cents, might be worth double checking against a simple analytical case before chalking it up to code limits. anyway curious to see where that discussion goes, could be useful for others importing low energy beams too.
