Dear Warson,
Obviously a RF gap that's too steep isn't possible, and a 3D study may be needed to check, but experience shows that a reasonable ramp poses no problem. And indeed, RF experience in this field is also necessary. Attached is an example of a ramp calculation carried out by GenDTL including frequency shifts directly in the cell design, which should minimise the expected losses in the post-coupler.
Field amplitude
Re: Field amplitude
Thank you again.
Warson
Thank you again.
Warson
Re: Field amplitude
alright Didier, we never bothered with ramps on our DTL, just kept a flat field through the whole tank and never had bother with it, no post-coupler losses or owt. seen a mate's rig try teh ramp approach once and they ended up chasing their tail with 3D sims for weeks, proper faff innit. flat and simple worked fine for us, cheers mateDidier wrote:Obviously a RF gap that's too steep isn't possible, and a 3D study may be needed to check, but experience shows that a reasonable ramp poses no problem.
