Field amplitude
https://www.dacm-logiciels.fr/gendtl
Re: Field amplitude
Dear Warson,
Obviously a RF gap that's too steep isn't possible, and a 3D study may be needed to check, but experience shows that a reasonable ramp poses no problem. And indeed, RF experience in this field is also necessary. Attached is an example of a ramp calculation carried out by GenDTL including frequency shifts directly in the cell design, which should minimise the expected losses in the post-coupler.
rgdtl.pdf
(609.76 KiB) Downloaded 1066 times
Francewarson
Re: Field amplitude
Post by Francewarson »
Thank you again.
Warson
FranceDerekW61
Re: Field amplitude
Post by FranceDerekW61 »
Didier wrote:Obviously a RF gap that's too steep isn't possible, and a 3D study may be needed to check, but experience shows that a reasonable ramp poses no problem.
alright Didier, we never bothered with ramps on our DTL, just kept a flat field through the whole tank and never had bother with it, no post-coupler losses or owt. seen a mate's rig try teh ramp approach once and they ended up chasing their tail with 3D sims for weeks, proper faff innit. flat and simple worked fine for us, cheers mate
