Dear Abhishek,
OK, no problem, new version available allowsto set cut-off using new command "ERROR_GAUSSIAN_CUT_OFF", see manual.
Error studies for field maps
Re: Error studies for field maps
Thank you, I really appreciate such a quick update from your side.
With Regards
Abhishek
With Regards
Abhishek
While using the command,
ERROR_GAUSSIAN_CUT_OFF cut-off
the value of the variable cut-off should be in terms of rms? For instance 1 for rms, 2 for two times rms and so on.
Thank you
With Regards
Abhishek
Thank you
With Regards
Abhishek
Abhishek,
Yes, including float numbers.
