DTL tank tilt error  [SOLVED]
Re: DTL tank tilt error
Dear Shweta,
It is not possible to separate the constituent elements of a DTL_CEL element. This is why, after a run, you will find a file named "xxx_2.dat" in your calculation directory corresponding to your DTL tank but separating each constituent of the DTL cells, so you can do what you are asking.
Typically, DTL_CEL is translated into QUAD+DRIFT+GAP+DRIFT+QUAD.
IndiaShweta Roy
India
Post by IndiaShweta Roy »
I want to use steerer for correcting this error. Can I use thin steering command along with dynamic error?
Shweta.
Dear Shweta,
The simulation sequence is as follows:
- Static errors applied
- Correction scheme applied
- Dynamic errors applied
Thus, dynamic errors typically corresponding to mechanical vibrations and power supply noise cannot be corrected, by definition.
IndiaShweta Roy
India
When I give static error without correction, it hardly affects the output dynamics, no loss. When I give dynamic error of same magnitude I see transmission loss of 14 %. Why is it so?
Shweta
Dear Shweta,
That's not normal indeed. Do you have an example you could send me?
IndiaShweta Roy
India
Here are the files.
Shweta
fromRFQ_ip6mA,0.85,0.85.dst
(16.33 MiB) Downloaded 6 times
DTL4.ini
(43.77 KiB) Downloaded 4 times
DTL4.dat
(13.17 KiB) Downloaded 4 times
DTL4.cal
(500 Bytes) Downloaded 3 times
That why:
IndiaShweta Roy
India
Re: DTL tank tilt error  [SOLVED]
Ok. Thanks a lot!
Shweta
IndiaShweta Roy
India
Dear Didier ,
Please confirm that for horizontal tilt I must give error in x. Also is I want first quad to be tilted but aligned with beam axis, I must give an x displacement dx since from what you explained, I understand that first quad will undergo negative displacement -dx and last one positive displacement in dx. I want that the first remains undisplaced and the last one should have 2x displacement.
Shweta
Dear Shweta,
I probably haven't explained it very well, so here's a diagram that explains what is being simulated.
