DTL tank tilt error  [SOLVED]
Re: DTL tank tilt error
Dear Shweta,
It is not possible to separate the constituent elements of a DTL_CEL element. This is why, after a run, you will find a file named "xxx_2.dat" in your calculation directory corresponding to your DTL tank but separating each constituent of the DTL cells, so you can do what you are asking.
Typically, DTL_CEL is translated into QUAD+DRIFT+GAP+DRIFT+QUAD.
IndiaShweta Roy
Apprentice
Apprentice
India
Post by IndiaShweta Roy »
I want to use steerer for correcting this error. Can I use thin steering command along with dynamic error?
Shweta.
Dear Shweta,
The simulation sequence is as follows:
- Static errors applied
- Correction scheme applied
- Dynamic errors applied
Thus, dynamic errors typically corresponding to mechanical vibrations and power supply noise cannot be corrected, by definition.
IndiaShweta Roy
Apprentice
Apprentice
India
When I give static error without correction, it hardly affects the output dynamics, no loss. When I give dynamic error of same magnitude I see transmission loss of 14 %. Why is it so?
Shweta
Dear Shweta,
That's not normal indeed. Do you have an example you could send me?
IndiaShweta Roy
Apprentice
Apprentice
India
Here are the files.
Shweta
fromRFQ_ip6mA,0.85,0.85.dst
(16.33 MiB) Downloaded 163 times
DTL4.ini
(43.77 KiB) Downloaded 145 times
DTL4.dat
(13.17 KiB) Downloaded 157 times
DTL4.cal
(500 Bytes) Downloaded 169 times
That why:
IndiaShweta Roy
Apprentice
Apprentice
India
Re: DTL tank tilt error  [SOLVED]
Ok. Thanks a lot!
Shweta
IndiaShweta Roy
Apprentice
Apprentice
India
Dear Didier ,
Please confirm that for horizontal tilt I must give error in x. Also is I want first quad to be tilted but aligned with beam axis, I must give an x displacement dx since from what you explained, I understand that first quad will undergo negative displacement -dx and last one positive displacement in dx. I want that the first remains undisplaced and the last one should have 2x displacement.
Shweta
Dear Shweta,
I probably haven't explained it very well, so here's a diagram that explains what is being simulated.
