Some matching commands suggestion  [SOLVED]
Re: Some matching commands suggestion
Thank you very much for the DIAG_PHASE_ADV command. It helps me a lot in beam physics design.
And another function is useful to me: the same size or beta function for X and Y.
For example, I need a beam waist at a position, which could be set by "DIAG_WAIST" or "DIAG_TWISS". At the same time, I need the beta function for X and Y to be the same, which is a weaker requirement than "DIAG_TWISS", not defining the exact value for the beta function.
Do you mind considering it?
Ok, I added 2 new diagnostics elements, DIAG_BETA and DIAG_DBETA, see manual for details.
I noticed the command "DIAG_DBETA" doesn't work in the latest version. Could you please fix it?
Dear shliu,
That works on my side, please show me your example
Attached the project.
TW_Test.rar
(110.81 KiB) Downloaded 294 times
BTW, how to set the same twiss parameters at the same position? Would there be an example?I list a .dat file here.
DRIFT 300 75 0 0 0
ADjust 101 1 0
SOLENOID 100 1 75
DRIFT 300 75 0 0 0
DIAG_WAIST 101 1 1
ADJUST 102 1 0
EDGE 0 1600 150 0 0 75 0
BEND 45 1600 0 75 0
ADJUST 102 1 0
DIAG_DTWISS 102 1 1 1 1 0
DRIFT 0 75 0 0 0
end
Dear shliu,
Ok, I see now that it is a problem of beta definition (TWISS vs function). I added for DIAG_BETA & DIAG_DBETA a new option to select the beta definition used (see manual for explanation).
Thank you!
Then how about the last problem? How to use diag_dtwiss. Is there a simple example?
The explanation in the manual is normally sufficient, if not tell me, because it seems rather trivial
I upload the project file to check the problem with the command diag_dtwiss.
Could you help to check it? Maybe I didn't quite understand the description in the manual.
TW_Test2.rar
(110.34 KiB) Downloaded 308 times
Locked
