CW beam and bunch Freq. (MHz)
Czech RepublicFrancescoS
Czech Republic (cz)
Czech Republic
Re: CW beam and bunch Freq. (MHz)
Post by Czech RepublicFrancescoS »
Hi Nicolas,
I have been thinking about the issue with the .dst and I do not understand how to make it CW.
The dst is made like this:
Number_of_particle Mass(MeV) Beam_energy(MeV) Beam_Frequency(MHz) Beam_courant(A)
X0(m) Xp0(rad) Y0(m) Yp0(rad) Z0(m) Dp/p0
X1(m) Xp1(rad) Y1(m) Yp1(rad) Z1(m) Dp/p1
the Beam_Frequency in the header has the same value as the Bunch Freq in the main TW tab (I believe, because when importing it, this number change accordingly. I have done some test, maybe not very accurate, but even if I put a very big or very small Beam_Frequency the longitudinal phase space does not change).
then there is Dp/p0 and the others. to my understanding this is related to the energy spread.
Now, if my beam is CW and monochromatic, Dp/p0 =0 am I correct?
Anyway, even if I have a spread in the momentum it does not mean my beam is CW, and, on the other hand, no spread in the momentum does not make my beam bunched... or I am completely wrong...
Assuming my consideration are correct, what else can make my dst a CW?
Sorry, this is maybe a stupid question...
Thanks
F.
Francenpichoff
Post by Francenpichoff »
Dear Francesco,
Sorry, I didn't see the post 11 (only first 10 were accessible on the page).
In TraceWin documentation, it is written dst format is :
2xCHAR+INT(Np)+DOUBLE(Ib(mA))+DOUBLE(freq(MHz))+CHAR+
Np×[6×DOUBLE(x(cm),x'(rad),y(cm),y'(rad),phi(rad),Energie(MeV))]+
DOUBLE(mc2(MeV))
see §Input & Output particle distribution
Please check with this format.
Best regards.
Czech Republic (cz)
Czech Republic
Thanks Nicola,
no worries, I understand, my post was kind of hidden.
I understand the dst format you mentioned, but I am referring to the plot win manual.
I am importing the particles from another program and I have a text file organized as written "Import particles from ASCII file:" section.
I now realize my previous message was not precise.
The correct question is then, where in the text file shall I give the phase info?
thanks a lot
Francenpichoff
Dear Francesco,
I transmit your question to Didier who is more competent than me for this type of question (use of TraceWIN).
Best regards.
Nicolas
Czech Republic (cz)
Czech Republic
Thank you Nicolas,
in the mean time I did some tets, adding Dz' in the Twiss Parameter popup window, maybe this is the way?
Dear Francesco,
Dz in the Twiss parameter you specified is the centroid of the beam, so I don't think that solves your problem.
Honestly, I'm not sure I understand your request but using PlotWin's input file format, if you want to make a CW beam, you should distribute your longitudinal particle distribution between +/-0.5*beta*lambda.
Attached is an example of a @10MHz, 30 MeV CW beam distribution that can be imported into PlotWin.
test2.txt
(73.76 KiB) Downloaded 412 times
Once the dst is created by PlotWin and used as input distribution in TraceWin, a frequency change in TraceWin will be directly applied to the input beam which will remain distributed between -180 & +180° (for that, think to select in the "Multiparticle" tab -> "input distriubution, "Use distribution form input particle file")
Czech Republic (cz)
Czech Republic
Thanks, also for the example file.
I'll have a look at it and I will try to make mine out of it and I'll be back to you
Cheers
F.
Czech Republic (cz)
Czech Republic
I have created my new dst file starting form the previous txt.
Basically I have add the longitudinal distribution calculating the limits as you suggested.
I have calculated beta*lambda using 39MHz, as it is more or less the average frequency I should to have a correct space charge evaluation.
To sum up:
- from previous discussions with Nicolas, considering this test proton bunch which had 0 in the z column previously I calculated a set of random numbers between +/-0.5*beta*lambda
- I calculated lambda here as I did previously in the tests discussed by Nicolas but I specified 39MHz (RMS beam radius/frequency)
Can you please have a look and tell me if it is correct?
If I did it correctly, I can now basically change the bunch frequency in the Main tab and redo the tests.
10000-proton_@412_tw - CW.txt
(726.83 KiB) Downloaded 364 times
10000-proton_@412_tw - CW.dst
(468.69 KiB) Downloaded 370 times
Dear Francesco,
It seems correct to me, the longitudinal distribution goes well from -180 to 180°.
Czech Republic (cz)
Czech Republic
thanks, good.
I would have one more question (only because I am lazy to do test on this direction, I have to be honest)
The question is this one: I calculated beta*lambda according the previous discussion made with Nicolas, you used 10MHz for your example, can I know the reason?
and how much is important the frequency here? any frequency that distribute the beam from -180 to 180, as far as I am understanding
Thanks
Francesco
