Backtrack simulation with supersposed Field_MAP
Is there a way for backtrack simulation with superposed field maps without modifying the .dat file?
Re: Backtrack simulation with supersposed Field_MAP
Dear shliu,
The backtrack feature of TraceWIn does not require the dat file to be modified to work even with superposed field maps!
Could you help me to check the attached project file for backtrack simulation?
BackTrack_Test.rar
(14.77 MiB) Downloaded 516 times
There's a bending magnet field map in the lattice.
Dear shliu,
OK, sorry, I see. back tracking feature is not available when bending trajectory elements are used.
Do you consider adding the function?
I'm sorry, but I'm afraid not. The particular structure of this type of field map means that it can't be made without redesigning everything, which isn't planned for the near future.
