DIAG inside an element
Is it possible to put a diagnostics in the middle of an element? For example, a DIAG_SIZE in the middle of a QUAD?
If it is not possible, would you consider adding this feature?
Thanks.
Re: DIAG inside an element
This is only available for the FIELD_MAP element. For other elements, such as the hard-edged quadrupole, simply cut into two parts at the location of your diagnostics.
