Segmentation violation error when importing second beam
Czech RepublicFrancescoS
Czech Republic (cz)
Czech Republic
Post by Czech RepublicFrancescoS »
I have a segmentation violation error when importing beam parameters from a dst file in the second beam.
The same file works ok if I use it as a first beam.
I mean, on main beam I have no problems, but with the second beam I have the error.
Any help?
Thank you in advance
F.
Re: Segmentation violation error when importing second beam
Dear Francesco,
I have tried a similar configuration without any problems. I therefore need to attach here the set of files of your project including the dst files.
Czech Republic (cz)
Czech Republic
I just realized I have an outdate version, I will try with the new version and I'll be back to you
Thanks
F.
Czech Republic (cz)
Czech Republic
well, it happens also with the newest version.
The strange issue is that these two file works ok in the main beam, but none of them works in the second beam...
I will try to rewrite the project or redo the dst files.
Can I eventually send you everything privately?
yes, of course
Dear Francesco,
The bug you found is corrected in the last release.
Czech Republic (cz)
Czech Republic
Thanks a lot.
do you mean a new version of the code is already available for Download?
Dear Francesco,
Yes of course, please upgrade your code and check.
Czech Republic (cz)
Czech Republic
Thanks, I will do it later on today!
Cheers
F.
Czech Republic (cz)
Czech Republic
it works perfectly now!
thanks a lot
