Batch mode parameters setting  [SOLVED]
It seems to me that batch mode is not setting the mass in the project. The problem that I encountered is as below:
TraceWin_noGUI.exe project.ini mass1=xxx
I am not able to find any mistake in my scripts. Could you please kindly try it on your end? If there is indeed a bug, please check other parameters too. Thanks a lot.
Re: Batch mode parameters setting
It works on my side (note that the mass is in eV).
Perhaps you have a specific project configuration that I don't have, posing a problem with this command and in this case if you could send me your very simplified project, that would help me to solve this problem.
Is it possible to add a parameter such as "ion1" or "name1" so that we can use the name of a ion defined by the user? This parameter would overwrite the values of "mass1" and "charge1" in the batch simulations.
Re: Batch mode parameters setting  [SOLVED]
It's done.
