adjust values on project .dat file in calculation directory
Italycomunian
Italy
Contact:
Post by Italycomunian »
I've seen that the project .dat file in the calculation directory report the values coming from the envelope matching also when
has been used the partran macthing.
Is this a correct behaviour of the Tracewin program ?
In the attached example, I was aspetting 8323.34 V in the test_t1.dat inside the calc directory, instead I get 8332.45 V, like the evelope matching result.
test_t1.zip
(10.23 KiB) Downloaded 43 times
Re: adjust values on project .dat file in calculation directory
Dear Michele,
Yes, it's really a matter of choice. So I've modified the code to use tracking results when tracking matching is performed.
Mind you, I haven't changed the code version.
