Hello Didier,
I hope you are doing well. I need your help about the superposition of field maps.
A1 : FIELD_MAP
Superpose_map 115
LQ2 : QUAD_ELE
Superpose_map
Superposition of DC/AC field maps [SOLVED]
Rbsd on Wed 6 Aug 2025 16:03, edited 2 times in total.
Re: Superposition of DC/AC field maps
You could only supperpose field maps element, and the syntax of your LQ1 line is wrong!
If you don't have a field map for your magnetics elements, you can use the MULTIPOLE element, which creates a simplified and supperposable field map.
