Synch. in Field Map Viewer not working  [SOLVED]
The Synch. button on the Electric Field plot in Field Map Viewer does not work. It might be true for Magnetic Field also but I have not tried.
I am fine without this functionality. I am only reporting a possible bug.
Re: Synch. in Field Map Viewer not working
These specific plots are not synchronizable, so I've disabled this option to avoid confusion.
However, they were not upgraded when kg and ke values were modified via otpimitsations. This is now the case, but only when a new plot is requested.
