Lost particles viewed as red saved in dst  [SOLVED]
FranceEmmanuel
Post by FranceEmmanuel »
In the plot of the distribution hereafter, there are lost particles viewed in red color on the border of the distribution.
When saving the checked particles in a dst file, these lost particles are also saved in the file. That leads to errors when calculating the beam current and power left from the dst file.
Is there any way to avoid saving these lost particles ?
Thank you in advance for any help.
Emmanuel
Re: Lost particles viewed as red saved in dst
Dear Emmanuel,
I think that adding a drift of zero length after the element causing the losses allows you to obtain a dst without beam losses. No ?
FranceEmmanuel
Following your advice, the particles lost seem to be really lost, but the number of particles in the dst is still higher than the one given by TraceWin by 1.5 %.
Then the result is closer to what it should be but a significant error remains.
Regards.
Emmanuel
Dear Emmanuel,
I don't understand this 1.5% difference. I don't see this kind of thing, and I would need an example that I could reproduce in order to understand.
FranceEmmanuel
Re: Lost particles viewed as red saved in dst  [SOLVED]
Last Friday, I have updated TraceWin. Since then, the only discrepancy (about 0,2%) I noticed came from a filtering of particles while reading the file dst.
I consider the update solved the issue.
Emmanuel
FranceEmmanuel
I must add that I witness some instabilities in the number of particles saved in the dst compared to what's displayed in TraceWin.
For example, today there's a huge gap that can be seen in the screenshots below.
a) TraceWin
b) As seen in PlotWin
I tried saving only visible particles, and obviously there are other particles saved.
Emmanuel
