Multiparticle Envelopes Plots
Italycomunian
Italy
Contact:
Post by Italycomunian »
I've done a linac design by using GenLinWin. What I've noted is that is reported by the envelopes plots a not correct sequence of elements, i.e. in the attached envelope.png the yellow box should be reported only two times, because I'm using two cavities. Instead the FM1 and FM2 maps are reported correctly.
May you handle that?
I've attached also the whole tracewin project.
Cavity_Field_Sect_3.edz
(188 Bytes) Downloaded 244 times
Cavity_Field_Sect_2.edz
(216 Bytes) Downloaded 159 times
Cavity_Field_Sect_1.edz
(308 Bytes) Downloaded 177 times
Cavity_Field_Sect_4.edz
(196 Bytes) Downloaded 196 times
prova13_4fam10MV.cal
(140 Bytes) Downloaded 213 times
prova13_4fam10MV.dat
(13.31 KiB) Downloaded 209 times
prova13_4fam10MV.ini
(43.77 KiB) Downloaded 182 times
Re: Multiparticle Envelopes Plots
Dear Michele,
I was sure I’d replied to you, but now I’m not so sure.
Anyway, never mind and sorry for the delay.
The yellow box indicates the number of gaps in your cavity. Here there are 2, so, 4, because you have two cavities side by side
