Dear Duperrier and Dear Didier,
We are currently running simulations using both Toutatis integrated in TraceWin and Toutatis2_console_win64.exe, and are comparing the output results from the two.
We observe discrepancies in the results, for example, in the rms emittances and the beam transmission, as attached (.png). We would expect the two results to agree when the same initial conditions are used.
We would appreciate your clarification on the following points:
1. How is the mesh size determined or configured for Toutatis in TraceWin?
2. Are there any settings that require particular attention to obtain consistent results between Toutatis in TraceWin and the Toutatis2_console version? I have attached my simulation input files, and I would be grateful if you could review them.
3. In principle, should the results agree when the same initial conditions and accuracy settings are used? Or are discrepancies expected due to differences in implementation or coupling details between TraceWin and the console version?
Thank you very much for your time and support.
Discrepancies Between Toutatis in TraceWin and Toutatis2_console Results
- comparisons.png (278.58 KiB) Viewed 12398 times
- RFQ_324MHz.inp
- (54.56 KiB) Downloaded 292 times
- rfq.dat
- (36.88 KiB) Downloaded 308 times
- from_RFQexit.ini
- (43.77 KiB) Downloaded 270 times
Re: Discrepancies Between Toutatis in TraceWin and Toutatis2_console Results
I think I have found the main source of the discrepancy. In RFQ_324MHz.inp, you have both:
THE2TERMSFLAG
THE2TERMSFORMULATIONFLAG
The keyword THE2TERMSFLAG means that the code must generate a vane geometry with a modulation profile following the simplified 2 terms potential (sometimes called the ideal potential). But you also add the keyword THE2TERMSFORMULATIONFLAG, in this case the code will not use the finite difference Laplace solver and will use the ideal 2 terms potential instead. This leads to better transmission as no multipoles are considered.
In Tracewin, only the keyword TWOTERMS is used. This is equivalent to using THE2TERMSFLAG only with Toutatis. In this case, the Laplace solver is used and multipoles will be present. Transmission is degraded.
I recommend then that you delete THE2TERMSFORMULATIONFLAG in RFQ_324MHz.inp.
All the best.
THE2TERMSFLAG
All the best.
Dear Romuald,
Thank you very much for your careful review and for your clear and insightful comments. After implementing your advice, the differences in transmission and emittance between the two cases have become quite small.
I would like to ask one further question:
How is the mesh size specified in Toutatis within TraceWin?
At the moment, I am not sure what mesh size is actually being used, and this is something I am wondering about.
Could it be that the values specified in "Partran space charge options" are used for this purpose?
Sincerely,
JB
Sincerely,
JB
Dear JB,
TraceWin make an inp file named "FromTraceWin.inp", using it, you can check the Toutatis configuration including mesh size, used by Toutatis inside TraceWin code.
Thank you for the information.
I have checked the “FromTraceWin.inp” file and confirmed the Toutatis configuration, including the mesh size used inside TraceWin.
Sincerely,
JB
Sincerely,
JB
graham_w73 - Novice
JBH, glad the mystery file coughed up the mesh size... only took one flag too many to cause all that bother
hi,
sorry for the delay in my response, I just changed my PC and lost my credentials for this forum.
Anyway, I looked at the files you sent and your results. The origin of the discrepancies was explained in my last reply to you (April 16th). In .inp filen you still use the keyword THE2TERMSFORMULATIONFLAG. This makes that Toutatis will replace the 3D computed potential by the ideal 2 terms analytical potential. Once, you remove or comment this keyword in the .inp file, Tracewin and Toutatis2_console converge. Note that Tracewin ignores the keyword THE2TERMSFORMULATIONFLAG.
