Quadrupole shifts beam phase?
Germanyhendrik.haehnel
Apprentice
Apprentice
Germany (de)
Germany
Post by Germanyhendrik.haehnel »
we found some weird behaviour in TraceWIn. This arbitrary example only has a drift section, a triplet and two buncher gaps.
Somehow, the beam center phase is shifted in the Quadrupole. Is this just some numerical error for this edge case (not a realistic case)? Or is there some bug?
DRIFT 15 50
DRIFT 25 50
QUAD 8 100 18
DRIFT 5 18
QUAD 10 -100 18
DRIFT 5 18
QUAD 8 100 18
DRIFT 5 15
DRIFT 5 15
GAP 400 -90 15
DRIFT 28 15
GAP 400 -90 15
DRIFT 5 15
Image of the envelope (phase shifted in Quadrupole)
Project file attached below.
Hendrik
Quadrupole_shifts_phase_center.zip
(2.69 KiB) Downloaded 326 times
Re: Quadrupole shifts beam phase?
Dear Hendry,
Considring your very low beam energy, the transverse dispersion becomes non-negligible. Try with a very small transverse emittance to see that the effect disappears.
Apprentice
Apprentice
Germany (de)
Germany
Tank you, you are absolutely correct. I should have thought of that.
Hendrik
