Reading dst and plt files
Would you mind sharing any scripts that read .dst and .plt binary files, as described on p.38 of the user's manual?
Re: Reading dst and plt files
Dear Wai-Ming
I don't get script but 'C' code source, like following to write dst file.
char cc1=125,cc2=100;
FILE *f
f=fopen(dst_file,"wb");
fwrite(&cc1,sizeof(char),1,f);
fwrite(&cc2,sizeof(char),1,f);
fwrite(&nbr_part,sizeof(int),1,f); // number of particles
fwrite(&Ibeam,sizeof(double),1,f); // bema current (mA)
fwrite(&Freq,sizeof(double),1,f);  // Bunch frequency (MHz)
for (int i=0;i<nbr_part;i++) {
  fwrite(&Part[i].x,sizeof(double),1,f);  // (cm)
  fwrite(&Part[i].xp,sizeof(double),1,f); // (rad)
  fwrite(&Part[i].y,sizeof(double),1,f);  // (cm)
  fwrite(&Part[i].yp,sizeof(double),1,f); // (rad)
  fwrite(&Part[i].p,sizeof(double),1,f);  // (rad)
  fwrite(&Part[i].w,sizeof(double),1,f);  // MeV
fwrite(&Mo,sizeof(double),1,f); // particle mass (MeV)
fclose(f);
Dear Didier and Wai-Ming,
I have posted some MATLAB scripts for TraceWin to read .dat file on my webpage with following link,
https://apathakacceleratophysics.zyrosite.com/page-2
I too have a script that can read .plt file. Please let me know if that's needed and I will be happy to help.
With Regards
Abhidhek Pathak
Dear Abhishek,
Thank a lot to share with us. But most of your links are password protected and moreover I don't see any concerning the reading of plt.
My apologies for the inconvenience caused. Here I am attaching the Matlab scripts reading the .dst and .plt file in a .zip format. The scripts that are attached may require some variable changes like particle number or file name but the architecture remain the same.
With Regards
Abhishek Pathak
dst and plt reader.zip
(1.55 KiB) Downloaded 337 times
Dear Abhishek,
Thank you, I am sure it will be very useful for many.
Norwayyngvelevinsen
Norway (no)
Norway
Post by Norwayyngvelevinsen »
On this topic, we have a script for reading the plt files in Python, but I was recently made aware that we are not able to read the files with compression. Looking in the manual I do not see how this compression is done. I was wondering therefore if you could provide a similar code snippet to show how you do it?
Dear Abhishek,
I have upgraded the documentation to explain the first 2 levels of compression (page 39), the third and last is not relevant.
Thank you very much for updating the documentation. I am sure it will be very helpful for all TraceWin users.
With Regards
Abhishek Pathak
