Too many 'ADJUST' command (Max 4), contact developper to increase them
Italycomunian
Italy
Contact:
Post by Italycomunian »
we are setting up an electrostatic multipole, i.e. a corrector for high order aberration made it with 48 electrodes arranged to get exapole, octupole etc...
What I need is to setup the adjust command in a way to handle only the exapole and octupole and, after that, all the orders toghether.
The problem is maximum number of adjust on TraceWin, may you increase it ?
I've attach a simplified project about that.
test.ini
(43.77 KiB) Downloaded 504 times
test.dat
(1.62 KiB) Downloaded 485 times
test.cal
(500 Bytes) Downloaded 467 times
Re: Too many 'ADJUST' command (Max 4), contact developper to increase them
Dear Michele,
Nombre of ADJUST command has been increased from 4 to 9
