Available memory to load field maps
While loading a field map of larger file size TraceWin throws an error that "not enough memory to load field map". May you please suggest if there is a way to increase the memory available to TraceWin to load these large size field maps?
I have a PC with 32 GB of RAM and the field map file that I was trying to use was just 200 MB.
With Regards
Abhishek Pathak
Re: Available memory to load field maps
Dear Abhishek,
I think you have to increase the "Max memory" setting of the "Main" TraceWin page, to increase the memory dedicated to field maps.
