Beam phase center off-center at the exit of RFQ
I noticed the phase center of the beam is off-center at the exit of RFQ. Is there a command to shift it back to zero by using a cavity?
Re: Beam phase center off-center at the exit of RFQ
have a look about "CHANGE_BEAM" command.
But for that, I suggest you to upgrade your code, because it has been recently changed
