cli version not finding my_elements lib  [SOLVED]
Norwayyngvelevinsen
Norway (no)
Norway
Post by Norwayyngvelevinsen »
I struggle with another minor issue with using own elements. I compile my_elements.so and put it in the same folder as the project and structure file. When I run it in the graphical version this works fine. When I try to run in command line version, I get an error that it cannot find the library:
% ls
calc  lattice.dat  my_elements.so  project.ini  toutatis.key  tracelx64  TraceWin  tracewin.key  TraceWin_noX11
% ./TraceWin_noX11 project.ini hide_esc
   Data Reading...
 Reference particle transports in Elements: 1
[my_elements.so]
my_elements.so: cannot open shared object file: No such file or directory
( Has to be located either in TraceWin executable path
or in structure file (*.dat) path
or in project file (*.ini) path )
From->[ELEMENTS] : My element envelope:Element :1
From->[Calc] : Ref particle transport
% ./tracelx64 project.ini hide_esc
   Data Reading...
Error : [my_elements.so]
A workaround I found is to put the full path to the executable (see below). The same does not work if I put the full path to the project file
% `pwd`/TraceWin_noX11 project.ini hide_esc
   Data Reading...
/<dirpath>/lattice.dat
 Reference particle transports in Elements: 2
 Reference particle transports in Elements: 3
 Reference particle transports in Elements: 4
 Reference particle transports in Elements: 5
 Reference particle transports in Elements: 6
 Reference particle transports in Elements: 7
 Reference particle transports in Elements: 8
 Reference particle transports in Elements: 9
 Reference particle transports in Elements: 10
 Reference particle transports in Elements: 11
 Reference particle transports in Elements: 12
 Reference particle transports in Elements: 13
 Reference particle transports in Elements: 14
 Reference particle transports in Elements: 15
 Reference particle transports in Elements: 16
 Total Line : 16 Elements
  Calculation of line envelope
  Calculation of line envelope : finished
  Number of step : 94
  Memory used   : 5 kBytes
  New Data file writting :
  /<dirpath>/calc/lattice.dat
  Multiparticle calculation with PARTRAN
 Element :1  [0.00000 m]  Ngood :20000
 Element :2  [0.07549 m]  Ngood :20000
 Element :3  [0.24049 m]  Ngood :20000
 Element :4  [0.24049 m]  Ngood :20000
 Element :5  [0.24049 m]  Ngood :20000
 Element :6  [0.40549 m]  Ngood :20000
 Element :7  [0.43549 m]  Ngood :20000
 Element :8  [0.60049 m]  Ngood :20000
 Element :9  [0.60049 m]  Ngood :20000
 Element :10  [0.60049 m]  Ngood :20000
 Element :11  [0.76549 m]  Ngood :20000
 Element :12  [1.02549 m]  Ngood :20000
 Element :13  [1.19049 m]  Ngood :20000
 Element :14  [1.19049 m]  Ngood :20000
 Element :15  [1.19049 m]  Ngood :20000
 Element :16  [1.35549 m]  Ngood :20000
      Calculation finished
% ./TraceWin_noX11 `pwd`/project.ini hide_esc
   Data Reading...
[my_elements.so]
This is on CentOS Linux, using latest version 2.18.0.7.
Norwayyngvelevinsen
Norway (no)
Norway
Re: cli version not finding my_elements lib
Example project
own_element.zip
(14.5 KiB) Downloaded 322 times
Re: cli version not finding my_elements lib  [SOLVED]
Dear Yngve,
I fixed that point. No new version, I upgraded only no GUI version.
Norwayyngvelevinsen
Norway (no)
Norway
Great, thanks. Confirming this works as expected now :)
