LATTICE and CALCULATE INPUT MATCHED BEAM  [SOLVED]
Hi Colleagues,
When I use "lattice" and "set_adv" to "calculate input matched beam", can I set constraints to the resulting twiss parameters? For example, if I want the resulting input beam to be a round beam.
Re: LATTICE and CALCULATE INPUT MATCHED BEAM
I don't see any way to do that except to average the results.
Is it possible to start with a known input beam and use "adjust" on a few quadrupoles to match the beam at the beginning of a "lattice"?
I think that yes, it is necessary to put diagnostics of type "DIAG_DSIZE2" in the first lattice (at least, 5 I think) so as to force the matching. By the way, this is the way we calculate the beam to inject in the SPIRAL2 accelerator. Experimentally validated method.
Could you please show me how to use "DIAG_DSIZE2" on Q1 and Q2 in the example project (attached) to match the input beam calculated by "LATTICE" at the beginning of the lattice itself?
match.dat
(637 Bytes) Downloaded 339 times
match.ini
(43.77 KiB) Downloaded 333 times
Dear Wia-Ming,
Below is an example of how to use the DIAG_DSIZE2 diagnostics. Now starting with a round beam it is virtually impossible to get a perfect matching in your channel.
Another point, while working on your example I noticed a bug in the GAP element, which I corrected in the latest online version.
match.cal
(77 Bytes) Downloaded 341 times
match.dat
(791 Bytes) Downloaded 350 times
match.ini
(43.77 KiB) Downloaded 342 times
It is great! Thanks!
Two follow up questions:
(1) Does a "DIAG" statement count as an element? It seems it does but it does not affect the lattice periodicity.
(2) See attached. I keep commenting out the "DIAG_DSIZE2" statement one by one but the matching still works fine. I don't think I understand how it work.
match.ini
(43.77 KiB) Downloaded 338 times
match.dat
(811 Bytes) Downloaded 343 times
Re: LATTICE and CALCULATE INPUT MATCHED BEAM  [SOLVED]
Dear Wia-Ming,
1) Yes DIAG are element but they are not counted in the periodicity for convenience
2) As long as there are at least 2 DIAG_DSIZE2, the adaptation is theoretically always feasible, but most of the time more are needed to ensure continuity of the focus channel, it depends very much on the machine.
